ONTAP Discussions
Insufficient Speed: Insufficient CPU Speed in MHz - speed is equal to what shows as a problem
BradParker
Hey y'all
So I'm getting the following error message when trying to deploy a cluster in ESXi. I'm not sure what kind of in formation y'all need to see if its a known issue--but let me know.
Thanks
Brad
1 ACCEPTED SOLUTION
cedric_renauld
Oupsy,
I think Select is not yet supported in vSphere 7.0u1 ..
I'llcheck it
6 REPLIES 6
cedric_renauld
Hello, Brad
Can you give us :
- ESXi Version
- Select Version you want ot deploy
- Number of ESXi
Deploy type = one / Tow / four nodes ?
Thanks
BradParker
You bet, thanks so much for responding!
- ESXi Version: 7.0u1
- Ontap Version 9.7
- Number of ESXi: I don't know what that is
Deploy type: 1
@cedric_renauld
cedric_renauld
Oupsy,
I'llcheck it
Oli71
@BradParker
Are you trying to install an OVA/OVF? This typical of CPU/RAM reservation message.
Edit your VM, go to the resource tab and remove all reservations.
Oli
jcolonfzenpr
what version of ontap select you deploy?
I used the standalone version and work correctly on my vmware homelab.
Jonathan Colón | Blog | Linkedin
ttran
Hi Brad_Parker,
@cedric_renauld is correct. ONTAP Select Deploy 9.7 currently is not compatible with VMWare ESXi 7.0 update 1; it is only compatible up to VMWare ESXi 6.7 update 3.
Here is the link to our NetApp Interoperability Matrix.
Regards,
Team NetApp
Team NetApp
