ONTAP Discussions
Is it possible to create widelink between 7-mode and cluster mode..?
vreddypalli
Hi,
We are using widelink feature in 7 mode setup.  Now the destination volume running in 7 mode is moved to Cluster mode due to space issues.
Are widelinks between 7 mode and cluster mode supported..? If yes what are the steps...? If I change unix mount point and the widelink entry to the respective vserver will it work..?
Regards,
Vijay R
2 REPLIES 2
sap_user1
Hi,
It works.  We have done this successfully.
Regards,
Vijay R
kodavali
widelink target can be on clustered ontap and it can also be on windows machine as well.
