ONTAP Discussions
Move or extract CIFS and NFS licens to another cluster using cli
Johan_K
Hi,
I used to have one cluster. NetappC1
2 newer nodes and 2 older ones in the cluster.
I removed the 2 older nodes from NetappC1
And created a new cluster NetappC2 with the older nodes.
So now i have 2 clusters (NetappC1 and NetappC2), NetappC1 with the 2 newer nodes and NetappC2 with the 2 older nodes.
Problem is now that I dont have the licenses for NetappC2,.
The Nodes are decommissioned and not in autosupport. So i cant find them.
Is there a way to extract the licenses from NetappC1?
I can see that there are still licenses on NetappC1 committed to the two nodes that are not in the cluster anymore.
::> system license show -serial-number 1-81-xxxxxxxxxxxxxxxx1
::> system license show -serial-number 1-81-xxxxxxxxxxxxxxxx2
Showing NFS, CIFS,iSCSI,FCP
But how do i move the licens to NetappC2?
1 ACCEPTED SOLUTION
SpindleNinja
There's not really a way to "extract them".     I'm also pretty sure those are node/serial locked as well.    If you're head swapping,  the new serials should be included with the order.
1 REPLY 1
SpindleNinja
