ONTAP Discussions
Need Ontap 8.1.4P1 for FAS2240
Kumaryogi
Hi Everyone..
Actually we have FAS2240 with Data Ontap 8.1.4P1 7-Mode and Filer-A had failed. So we have replaced with New one.
But unfortunately forgot to swap Flash Card from failed filer to new filer.
In result the New Filer is having Ontap 8.2P3 7-Mode has been configured that  newer version then we have in out system.
So system is running but Takeover feature has been disabled due to ontap mismatch.
strga> cf status
strgb is up, takeover disabled because of reason (version mismatch)
strga has disabled takeover by strgb (version mismatch)
        NVRAM TOC: Local 29 Partner 23
        WAFL FSInfo: Local 23589 Partner 22331
        WAFL log: Local 396 Partner 334
        RAID: Local 12 Partner 11
        RAID NVRAM: Local 42 Partner 33
VIA Interconnect is up (link up).
So now we have two options here, one need to upgrade Filer-B to 8.2P3 or downgrade Filer-A to 8.1.4P1.
But to perform both we need those Ontap Firmware. we have tried to search Netapp Support but unable to find any version blow 8.5
So I need help here if someone pls share link to download above version will be really helpful to me
Thank You
20 REPLIES 20
maffo
hi @Kumaryogi
8.1 is in self service support and its downloads are no longer available from NetApp support site.
For 8.2 you can download the 8.2.5P3 release which is the latest one and bring both controllers to that version; please beware that in this stage you will not be able to perform a non-disruptive upgrade due to the inability of performing takeover at the moment.
Kumaryogi
Dear maffo,
I was thinking if there are some FTP or archive link for old firmware.
Our customized applications are designed in such way that we have advised to stuck on 8.1.4P1 only.
So we have to contact to our application programmers and work with compatibility with new 8.2 version.
Well thanks to  you for quick reply and suggestion..
I sincerely appreciating your advise here..
Thanks 🙂
maffo
Hi @Kumaryogi
unfortunately we do not offer old software (not just ONTAP) when it's past the end of support date.
Please be also aware that 8.1.4 has also not been updated in a while with regards to security fixes: if you have a custom application developed for it, then indeed you will have to confirm it's still compatible with 8.2.5P3 or upgrade it as needed.
Tolga_Yilmaz
Hello , did you find the files ? Can you share with me too ?  i also need 8.1 ontap version ...
Kumaryogi
Hi
Which ontap version you are looking for
8.1.3q  or 8.1.4P1q
Tolga_Yilmaz
Hello ,
my email is [removed] you can send me link here if you have 🙂
that is my revert_to  output , system is tellin i need 8.1   , i think  any version is ok for me .
Netapp> revert_to
revert_to [-sd] 8.1 (for 8.1 and 8.1.x)
revert_to [-sd] 8.1c (for clustered 8.1 and 8.1.x)
-s Attempt to revert by skipping the configuration checks on MLM devices and LUNs.
-d Bypass check for backlog of asynchronous deletes.
Netapp>
Tolga_Yilmaz
Thank you for sharing me the links , i solved my problem for license keys .   My box was 8.2 and i wiped it so i lost licenses and only have the licenses when i got this storage with 7 digit licenses which ones not acceptable at 8.2 ontap version.  Now i revert to  8.1 and enter my licenses than i upgrade to 8.2 and licenses were also updated automatically.. I really appreciate for your help!
JMU
Hello,
I have an old 2240 with two nodes on 7 mode and i want to rollback them to 8.1.3q  or 8.1.4P1q because i want to use old license system and i wipe all.
Anybody can share the link please ?
Thanks in advance.
Best regards.
Tolga_Yilmaz
Hello ,
yes i have the files and can share with you 🙂
JMU
Hello,
Thank you for the share 🙂
the rollback Work !
Regards,
Sruiz
Dear Tolga
I have the same problem, please , could you please share me the ontap 8.1?
Thanks
dmtsh
Dear Tolga,
Could you please share with me the ONTAP 8.1 image?
Thanks
GidonMarcus
Hi, you can take the files from /etc/boot/x86_elf on the working controller then netboot and install the new one with these files.  (you can also copy them to the other flash card if you have a reader).
Here's how to set the partner to be a netboot server.
https://www.youtube.com/watch?v=-DwaeNEDr2U
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
SpindleNinja
doesn't work.   just links to the main downloads page.
They've all been pulled as far as I can tell.
Hasan-Bozok
I need Ontap 8.1.4P1 for FAS2240. Can anyone who has 8.1.4P1 in your hand please share it with me?
Kumaryogi
Hi Hasan
I have "8.1.4P1q" for FAS22xx . is this will be helpful to you
Hasan-Bozok
Hi Kumar,
Yes, if I downgrade my device's 8.1 firmware, my licenses will work. You can share the firmware image through any platform. thank you very much.
Kumaryogi
Hi Hasan,
pls check your inbox have share u link..
regards
Hasan-Bozok
Hi Kumar,
I downloaded the file you shared. When I want to downgrade the firmware to the device, I encounter the warning I shared in the attachment.
