ONTAP Discussions
ONTAP Edge to ONTAP Edge T
jezowski
Can ONTAP Edge be 'upgraded' to ONTAP Edge T and is there a cost associated with that?
Thanks.
5 REPLIES 5
BUMPSTEADT
From what I can tell, the difference is just the platform key used when deploying from dvadmin.
jgoldsch
Troy,
There is no upgrade path from Edge to Edge-T - these are different products managed by different software license keys.
The Data ONTAP Edge datasheet provides a nice comparison of the two offerings:
http://media.netapp.com/documents/ds-data-ontap-edge.pdf
hanar
    There is no upgrade path from Edge to Edge-T.  They are the equivalent of buying two different hardware platforms.  Once they are installed, they set a “hardware” personality.  You can’t upgrade to Edge-T as it is a different model number and associated serial number.  You would need to buy an Edge-T version and migrate the data over to that virtual machine.
jezowski
So that would imply a customer who previously purchased ONTAP Edge has no "trade-in credit" or way to make use of those software licenses if they were to purchase ONTAP Edge-T. Correct?
michelznetapp
Hey guys
I know i'm digging up an old thread. But there is a "desaster recovery" procedure that you can re-install ONTAP Edge using "just" the data disks.
I believe that would allow for an upgrade.
Is there still no possibility to do a "trade-in" of an ONTAP Edge and upgrade to a Edge-T ?  I mean this is after all possible with the Hardware-FAS as well (Head-Swap for instance)
Any takers here?
