ONTAP Discussions
Ontap 9xxx: 2038 problem
dsu
Hello
We use for testing purposes Ontap version 9.xx, to test our scanner software. We have now the problem that in case, we use the function to set back the "Last Accessed" date in fact the LAD timestamp date is set to 19.january 2038.
Do this problem exists in version 10.xx too? I understand that this is a unix based timecode problem of 32 bit.
Thank you in advance
1 ACCEPTED SOLUTION
Ontapforrum
I see there is a bug record:
NetApp Support Site - BURT - 927165
Check if your Ontap is in the list of found in versions.
1 REPLY 1
Ontapforrum
