ONTAP Discussions
Ontap Select help me to counter Multiprotocol issues, Usermapping,HA Solution  and Snapmirror
SharmaVik
Hello,
Can some one assist me how Ontap Select help me to counter Multiprotocol issues, Usermapping,HA Solution  and Snapmirror. Need little discription for each
1 ACCEPTED SOLUTION
Mjizzini
AutoSupport is the primary troubleshooting tool used by NetApp to support ONTAP Select.
The best way to manage Ontap Select  is through System Manager.
HA, Usermapping, and snapmirror still deliver the same features but  are virtualized.
Below is Netapp ONTAP Select  repository.
If you are working with ONTAP Select 9.7 or later, you can find the most current ONTAP Select documentation at
https://docs.netapp.com/us-en/ontap-select/
Illustration of the ONTAP Select networks and nodes
https://library.netapp.com/ecmdocs/ECMLP2600453/html/GUID-BC43C529-F228-49E4-AB3E-0B2A3B0FB857.html
1 REPLY 1
Mjizzini
