ONTAP Discussions
Oracle Advanced Compression
mleal2005
I can't seem to find any recommendations on using Oracle Advanced Compression with AFF storage arrays. Mainly looking for guidance on the configuration of aggregate compaction and volume dedupe and compression settings. Should they all stay enabled, or can OAC be used in conjunction with those technologies.
3 REPLIES 3
Ontapforrum
It's a good question. I see one blog post from oracle, may be worth taking a look.
Oracle Advanced Compression Compared to Storage-Based Compression – The Important Differences
dkrenik
Good post - I worked with Gregg Christman when I worked at Oracle.
ACO (Advanced Compression Option) is a collection of numerous features.  It might be helpful to know which features are being used and how.
Tastes like chicken
Mjizzini
Below is the Technical Report of Oracle databases on ONTAP.
Technical Report Oracle databases on ONTAP
