ONTAP Discussions
Possible to create traditional aggregate and volume on Netapp Ontap 9.14?
jeffrey24
Qns as above.... I'm facing issues joining my SVM to Windows 2003 AD for CIFS Share.... Read in another thread that it's possible to do so if my volume is non-flexgroup.
https://community.netapp.com/t5/ONTAP-Discussions/Windows-2003-access-CIFS-share-folder/m-p/161382
Would appreciate any help, thanks.
@parisi Are you able to advice on how you created a non-flexgroup volume on Netapp 9.12?
1 ACCEPTED SOLUTION
chenguanghui
hello:First,  you need to check if SMB1 is enabled. Since ONTAP 9.10.1, it is not allowed to create FlexGroup volumes that have SMB1 enabled. However, https://kb-cn.netapp.com/on-prem/ontap/Ontap_OS/OS-KBs/Why_FlexGroup_volume_is_created_failed_by_SMB1_not_supported_error_on_ONTAP_9_12_1
traditional volumes and aggregates can be created normally.
1 REPLY 1
chenguanghui
