ONTAP Discussions
Problem adding iSCSI Storage Array
RICKSAAVEDRA
After installing plugin I am trying to add iSCSI storage server. I put in the required info and get the folling error. Was wondering if a specific ONTAP version is required and/or a particular license that is needed?
Thanks
Rick
Job Construction Phase
begin()
begin()
Appended operation 'Storage Array Validate' to object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'.
Appended operation 'Storage Array Discover Info' to object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'.
Appended operation 'Storage Server Discover Capabilities' to object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'.
Appended operation 'Storage Server Discover Access Groups' to object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'.
Operation 'Storage Array Discover Info' was not added, it already exists on object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'.
Appended operation 'Storage Array Discover Storage Elements' to object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'.
Appended operation 'ISCSI Storage Array Discover Targets' to object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'.
commit()
Completed Step: COMMIT
Objects and Operations
Object (CREATED): [IscsiStorageArray] 0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)
Operation: Storage Array Validate
Operation: Storage Array Discover Info
Operation: Storage Server Discover Capabilities
Operation: Storage Server Discover Access Groups
Operation: Storage Array Discover Storage Elements
Operation: ISCSI Storage Array Discover Targets
Object (IN_USE): [StorageArrayPlugin] oracle.netapp.SCSIPlugin.StoragePlugin (1.2.7--0-) (Oracle NetApp Filer Plugin)
Object (IN_USE): [Server] 00:18:fe:89:84:62:00:18:fe:89:84:66:ff:ff:ff:ff (z7-ovm1-serv)
Job Running Phase at 13:33 on Wed, Dec 5, 2012
Job Participants: [00:18:fe:89:84:62:00:18:fe:89:84:66:ff:ff:ff:ff (z7-ovm1-serv)]
Actioner
Starting operation 'Storage Array Validate' on object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'
Job Internal Error (Operation)com.oracle.ovm.mgr.api.exception.FailedOperationException: OVMAPI_B000E Storage plugin command [storage_plugin_validate] failed for storage server [0004fb0000090000548b0dbbdad1ed97] failed with [com.oracle.ovm.mgr.api.exception.FailedOperationException: OVMAPI_4010E Attempt to send command: storage_plugin_validate to server: z7-ovm1-serv failed. OVMAPI_4004E Server Failed Command: storage_plugin_validate oracle.netapp.SCSIPlugin.StoragePlugin, Status: OSCPlugin.OperationFailedEx:'NetApp Data ONTAP Failure: failed'
Wed Dec 05 13:33:37 EST 2012
Wed Dec 05 13:33:37 EST 2012] OVMAPI_4010E Attempt to send command: storage_plugin_validate to server: z7-ovm1-serv failed. OVMAPI_4004E Server Failed Command: storage_plugin_validate oracle.netapp.SCSIPlugin.StoragePlugin, Status: org.apache.xmlrpc.XmlRpcException: OSCPlugin.OperationFailedEx:'NetApp Data ONTAP Failure: failed'
at com.oracle.ovm.mgr.action.StoragePluginAction.processException(StoragePluginAction.java:1371)
at com.oracle.ovm.mgr.action.StoragePluginAction.validate(StoragePluginAction.java:106)
at com.oracle.ovm.mgr.op.physical.storage.StorageServerValidate.validate(StorageServerValidate.java:54)
at com.oracle.ovm.mgr.op.physical.storage.StorageServerValidate.action(StorageServerValidate.java:40)
at com.oracle.ovm.mgr.op.physical.storage.StorageArrayValidate.action(StorageArrayValidate.java:31)
at com.oracle.ovm.mgr.api.collectable.ManagedObjectDbImpl.executeCurrentJobOperationAction(ManagedObjectDbImpl.java:1009)
at com.oracle.odof.core.AbstractVessel.invokeMethod(AbstractVessel.java:330)
at com.oracle.odof.core.AbstractVessel.invokeMethod(AbstractVessel.java:290)
at com.oracle.odof.core.storage.Transaction.invokeMethod(Transaction.java:822)
at com.oracle.odof.core.Exchange.invokeMethod(Exchange.java:245)
at com.oracle.ovm.mgr.api.physical.storage.IscsiStorageArrayProxy.executeCurrentJobOperationAction(Unknown Source)
at com.oracle.ovm.mgr.api.job.JobEngine.operationActioner(JobEngine.java:218)
at com.oracle.ovm.mgr.api.job.JobEngine.objectActioner(JobEngine.java:309)
at com.oracle.ovm.mgr.api.job.InternalJobDbImpl.objectCommitter(InternalJobDbImpl.java:1140)
at com.oracle.odof.core.BasicWork.invokeMethod(BasicWork.java:136)
at com.oracle.odof.command.InvokeMethodCommand.process(InvokeMethodCommand.java:100)
at com.oracle.odof.core.BasicWork.processCommand(BasicWork.java:81)
at com.oracle.odof.core.TransactionManager.processCommand(TransactionManager.java:773)
at com.oracle.odof.core.WorkflowManager.processCommand(WorkflowManager.java:401)
at com.oracle.odof.core.WorkflowManager.processWork(WorkflowManager.java:459)
at com.oracle.odof.io.AbstractClient.run(AbstractClient.java:42)
at java.lang.Thread.run(Thread.java:662)
Caused by: com.oracle.ovm.mgr.api.exception.FailedOperationException: OVMAPI_4010E Attempt to send command: storage_plugin_validate to server: z7-ovm1-serv failed. OVMAPI_4004E Server Failed Command: storage_plugin_validate oracle.netapp.SCSIPlugin.StoragePlugin, Status: org.apache.xmlrpc.XmlRpcException: OSCPlugin.OperationFailedEx:'NetApp Data ONTAP Failure: failed'
at com.oracle.ovm.mgr.action.ActionEngine.sendCommandToServer(ActionEngine.java:507)
at com.oracle.ovm.mgr.action.ActionEngine.sendUndispatchedServerCommand(ActionEngine.java:459)
at com.oracle.ovm.mgr.action.ActionEngine.sendServerCommand(ActionEngine.java:385)
at com.oracle.ovm.mgr.action.StoragePluginAction.validate(StoragePluginAction.java:102)
... 30 more
Caused by: com.oracle.ovm.mgr.api.exception.IllegalOperationException: OVMAPI_4004E Server Failed Command: storage_plugin_validate oracle.netapp.SCSIPlugin.StoragePlugin, Status: org.apache.xmlrpc.XmlRpcException: OSCPlugin.OperationFailedEx:'NetApp Data ONTAP Failure: failed'
at com.oracle.ovm.mgr.action.ActionEngine.sendAction(ActionEngine.java:798)
at com.oracle.ovm.mgr.action.ActionEngine.sendCommandToServer(ActionEngine.java:503)
... 33 more
FailedOperationCleanup
Starting failed operation 'Storage Array Validate' cleanup on object 'z7-filerc-serv'
Complete rollback operation 'Storage Array Validate' completed with direction=z7-filerc-serv
Rollbacker
Executing rollback operation 'Storage Array Validate' on object '0004fb0000090000548b0dbbdad1ed97 (z7-filerc-serv)'
Complete rollback operation 'Storage Array Validate' completed with direction=DONE
Objects To Be Rolled Back
Write Methods Invoked
Class=InternalJobDbImpl vessel_id=964 method=addTransactionIdentifier accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=addAdminServer accessLevel=6
Class=ServerDbImpl vessel_id=523 method=addStorageServer accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=validate accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=refresh accessLevel=6
Class=InternalJobDbImpl vessel_id=964 method=setCompletedStep accessLevel=6
Class=InternalJobDbImpl vessel_id=964 method=setAssociatedHandles accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=nextJobOperation accessLevel=6
Class=InternalJobDbImpl vessel_id=964 method=setFailedOperation accessLevel=6
Class=StorageArrayPluginDbImpl vessel_id=912 method=nextJobOperation accessLevel=6
Class=ServerDbImpl vessel_id=523 method=nextJobOperation accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setName accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setFoundryContext accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=onPersistableCreate accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setLifecycleState accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setRollbackLifecycleState accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setStoragePlugin accessLevel=6
Class=StorageArrayPluginDbImpl vessel_id=912 method=addStorageServer accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setAdminHostname accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setAdminUsername accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setAdminPassword accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setSimpleName accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setDescription accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setAccessHost accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setAccessPort accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setUsername accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setPassword accessLevel=6
Class=IscsiStorageArrayDbImpl vessel_id=973 method=setUseChapAuth accessLevel=6
Completed Step: ROLLBACK
Job failed commit (internal) due to OVMAPI_B000E Storage plugin command [storage_plugin_validate] failed for storage server [0004fb0000090000548b0dbbdad1ed97] failed with [com.oracle.ovm.mgr.api.exception.FailedOperationException: OVMAPI_4010E Attempt to send command: storage_plugin_validate to server: z7-ovm1-serv failed. OVMAPI_4004E Server Failed Command: storage_plugin_validate oracle.netapp.SCSIPlugin.StoragePlugin, Status: OSCPlugin.OperationFailedEx:'NetApp Data ONTAP Failure: failed'
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
... 30 more
... 33 more
End of Job
1 ACCEPTED SOLUTION
nkarthik
Hello Rick,
1.       1. Can you provide your ontap version.
2.      2.  Hope you have the flexclone licese installed in the storage.
3.      3.  Make sure “z7-filerc-serv” is resolveable or try with ip instead of “z7-filerc-serv” name.
regards,
karthikeyan.N
2 REPLIES 2
nkarthik
Hello Rick,
regards,
karthikeyan.N
RICKSAAVEDRA
Thanks hikeyan.N. Using the IP address instead of the hostname did the trick.
Regards
Rick
