ONTAP Discussions
Problem with CPU utilisation using ansible
Americano
We have developed an automation Ansible script which logs into the ONTAP System and fetch the details of the igroups whose initiators are not-logged in.
This script logs into the ONTAP System multiple times, and in context to that please let us know if this can cause an issue on the Storage at any given time.
Please highlight if this repeated login by the script on the ONTAP system can put the Storage in a non-ideal situation.
--> We also want to know the impact on ontap node i.e, CPU utilization on Ontap node to use the script to try login attempts to the storage after each 30 or 40 secs to fetch the requested information.
Please advice
 --> What is the amount of CPU utilization may cause if the scripts attempts login for every 30s to Storage
Looking forward to your response.
Thank you!
0 REPLIES 0
