ONTAP Discussions
Problem with SMI-S Configuration
LWJOUBERT
Hi
I installed SMI-S version 4.0.1 and is trying to configure it for use in SCVMM 2012.
1. Created a User & Password.
2. Checked the status / restarts etc.
Outputs:
C:\>ping 10.0.100.201
Pinging 10.0.100.201 with 32 bytes of data:
Reply from 10.0.100.201: bytes=32 time<1ms TTL=254
  Ping statistics for 10.0.100.201:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
\>SMIS Netapp N3t@pp version
ONTAP_SMIAgentSoftware.InstanceID="ONTAP:4.0.1"
\>SMIS Netapp N3t@pp add 10.0.100.201 USER01 PASS01
\cimcli CIMException:  Cmd= ci Object= ONTAP_FilerData Code= 1
CIM_ERR_FAILED: Can't connect to host (err=10061). - With storage system 10.0.100.201
I have another controller on IP 10.0.100.202 these two is configured in HA.
Please help
Why can I not connect ???
W
2 REPLIES 2
psrao
Wessel,
Could you please seed us the agent log/trace files from C:\Program files\ontap\smis\pegasus\traces directory.
- Sreeni
wangruifeng
This message can occur when http access is not enabled on the filer.
Please consult the correct documentation for your Ontap OS version to enable http access.
Suggest you to config as follows:
     options httpd.enable on
     options httpd.admin.enable on
the try  again smis add conmmad
