ONTAP Discussions
Problem with harvest on debian buster
LORENZO_CONTI
Hello,
I'm experiencing an issue with harvest 1.6 on debian buster.
When I start the poller, it seems running initially, but it suddenly crashes. I tried to debug with the command
/opt/netapp-harvest/netapp-worker -poller $pollername -v
And the last output line is
32063: ssl ctx set options
Could someone help to troubleshoot this issue?
Thank you
1 ACCEPTED SOLUTION
LORENZO_CONTI
Hello,
after some investigation we found the issue was related to this setting in /etc/ssl/openssl.cnf
CipherString = DEFAULT@SECLEVEL=2
was commented out for other reason, uncommenting fixed the issue with harvest 🙂
2 REPLIES 2
Mjizzini
Is there warning/errors in the verbose poller logs?
NetApp Harvest Administration Guide
LORENZO_CONTI
Hello,
