ONTAP Discussions
Question about De-Dupe limitations and OnTap versions
storage_ergo
Hello All,
I have received mixed answers to this question so I thought I would post it here to get some feedback.
I was told in the past that limitations on de-duplication are dependent on FAS platform not ONTAP version.
However based on page 19 of this guide
http://media.netapp.com/documents/tr-3505.pdf
It seems that it is dependent on ONTAP version and 7.3 has higher limits vs 7.2.
Can someone clear this up for me ? Is it a combination of both hardware and software limitations ?
Thanks
3 REPLIES 3
danielmorgenstern
Yes, both hardware and ONTAP version are involved.
Generally, dedupe volume limits are based on the hardware.  However, changes in recent versions of ONTAP have resulted in the dedupe volume limits for certain units increasing as reflected in the chart for ONTAP 7.3.1+
Regards,
Dan
storage_ergo
Thank you Daniel,
Has there been anything published regarding 8.0 7G mode and deduplication limits  ? Does anything change from 7.3 ?
radek_kubka
Hi,
It wasn't easy to find, but there you go:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel80rc2/pdfs/ontap/onlinebk.pdf
table on page 280
Limits look unchanged comparing to 7.3.2:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel732/html/ontap/onlinebk/GUID-2FD76C49-08CE-47BA-972D-E0F578DF6575.html
The documentation is about 8.0 RC2 though, so it can be a moving target.
Interestingly enough, no one was bothered to mention FAS2040 in 8.0RC2 limits and according to my best knowledge this box will run ONTAP 8 happily.
Regards,
Radek
