ONTAP Discussions
Rename SnapVault destination volume and not lose any snapshots
Stormont
We have a few volumes that are in SnapVault relationships where the destination volume was named incorrectly.  What are the steps that we need to take in order to rename the destination volumes and save all of the snapshots that have been copied so far?
1 ACCEPTED SOLUTION
Stormont
Thank you.  We know how to rename volumes, but everything that we read made it sound like a more involved process when you are renaming a SnapMirror/Vault target.  Luckily it turned out that if you rename the target volume, the relationship is automatically updated when running CDOT.
2 REPLIES 2
AlexDawson
Hi there,
This document outlines the process for 7-Mode - https://kb.netapp.com/app/answers/answer_view/a_id/1034843/loc/en_US#__highlight
For Clustered ONTAP (8.3 and later), you would use the volume rename and snapmirror modify commands
Hope this helps!
Stormont
