ONTAP Discussions
UNABLE to connect ontap filer using connect-nacontroller
AJAYKUMARN
Hello All,
I'm new to the Netapp Powershell...
After succesfulling installing the Netapp powershell module, unable to connect to the filer using "Connect-NaController"
Fas version : 8.1.4
Powershell version :
Major  Minor  Build  Revision
3      0      -1     -1
http,https,tls/ssl is enabled...  used force secure/unsecure option.. But, stil unable to login.. Could you please share your thoughts here ?
options ssl
ssl.enable                   on
ssl.v2.enable                on         (same value required in local+partner)
ssl.v3.enable                on         (same value required in local+partner)
httpd.access                 legacy
httpd.admin.access           *
httpd.admin.enable           on
httpd.admin.hostsequiv.enable off
httpd.admin.max_connections  512
httpd.admin.ssl.enable       on
httpd.admin.top-page.authentication on
httpd.autoindex.enable       off
httpd.bypass_traverse_checking off
httpd.enable                 off
httpd.ipv6.enable            off
httpd.log.format             common     (value might be overwritten in takeover)
httpd.method.trace.enable    off
httpd.rootdir                /vol/vol0/home/http
httpd.timeout                300        (value might be overwritten in takeover)
httpd.timewait.enable        off        (value might be overwritten in takeover)
options tls
tls.enable                   on         (same value required in local+partner)
PS C:\Windows\system32> Connect-NaController 172.27.10.111
Connect-NaController : Failed to load ntapadmin64 DLL
At line:1 char:1
+ Connect-NaController 172.27.10.111
    + CategoryInfo          : InvalidResult: (172.27.10.111:NaController) [Connect-NaController], Exception
    + FullyQualifiedErrorId : RpcConnectionFailed,DataONTAP.PowerShell.SDK.ConnectNaController
PS C:\Windows\system32> Connect-NaController 172.27.10.111 -ForceUnsecure
Connect-NaController : Connection to 172.27.10.111 on port 80 for protocol HTTP timed out.
At line:1 char:1
+ Connect-NaController 172.27.10.111 -ForceUnsecure
    + CategoryInfo          : InvalidResult: (172.27.10.111:NaController) [Connect-NaController], NaConnectionTimeoutE
   xception
    + FullyQualifiedErrorId : HttpConnectionFailed,DataONTAP.PowerShell.SDK.ConnectNaController
PS C:\Windows\system32> Connect-NaController 172.27.10.111 -Forcesecure
Connect-NaController : Connection to 172.27.10.111 using HTTPS failed - The request was aborted: Could not create
SSL/TLS secure channel.
The error may be resolved by generating a new certificate on the storage controller, with a longer key length.
At line:1 char:1
+ Connect-NaController 172.27.10.111 -Forcesecure
    + CategoryInfo          : InvalidResult: (172.27.10.111:NaController) [Connect-NaController], NaConnectionSSLExcep
   tion
1 REPLY 1
asulliva
Hello @AJAYKUMARN,
We just had a discussion on the issue you're encountering ("Failed to load ntapadmin64 DLL") over here.  Hopefully the workaround suggested there works for you.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
