ONTAP Discussions
Unable to connect to management interface of NetApp storage device
regine
I am getting this error when i try to connect to the Management interface (with ip address <ip>) of the NetApp storage device from the SMI-S agent which is a windows server VM.
command typed on SMI-S agent:
> smis addsecure <ip> <username>
error:
cimcli CIMException Cmd=ci Object=ONTAP_FilerData Code=1 CIM_ERR_FAILED:Filer return:can't connect to host <err=10060>. - With storage system <ip>
Please help!
4 REPLIES 4
NAYABSK
Hi,
Thank you for contacting NetApp community, May i know if you have enabled http or https to complete this operation ?
7-Mode:-
options httpd.enable on
options httpd.admin.enable on
C-Mode:-
system services web modify -http-enabled true
system services web modify -https-enabled true
Then try again smis command and let us know.
Thanks,
Nayab
regine
I did set http and https to true. Below is the output of the "system services web show" command on the netapp storage device:
External Web Services: true
Status: online
HTTP Protocol Port: 80
HTTPs Protocol Port: 443
TLSv1 Enabled: true
SSLv3 Enabled: false
SSL FIPS 140-2 Enabled: false
suna
Can you check your windows firewall is disabled?
regine
yes.firewall is disabled.
