ONTAP Discussions
Using cluster failover on a 3140 to replace with 3270?
TONY_RICCIOTTI
I was curious if I could migrate the high side cluster from a 3140 to a 3270 by:
1: Force a takeover on one of the 3140 controllers
2: Turn off clustering and operate the 3140 on a single controller
3: Configure one 3270 as the new cluster partner
4: Execute a giveback
5: Force a takeover from the 3270
6: Break the cluster and decommission the 3140
7: Configure the second 3270 as a partner
8: Execute a giveback
Am I completely off of my rocker or should this work?
Thanks
Tony
2 REPLIES 2
aborzenkov
No, it is not possible. For a start, they are using completely different interconnect technologies.
TONY_RICCIOTTI
I figured that to be the case, I was just hoping. Thanks
