ONTAP Discussions
Volume move between aggregates
Eldhose
I got a task to move a volume from one aggregate to another aggregate in the same netapp cluster .
We are using GUI oncommand system manager for this.
The volume which am moving is the mirror volume of primary site. Before initiating the volume movement, Do i need to stop the snapmirror ?
1 REPLY 1
christsai
Hi
You don't need to stop the snapmirror before volume move.
The source volume of a SnapMirror or SnapVault relationship can be moved while the volume is being mirrored. SnapMirror services encounter a brief pause during the cutover phase of the volume move job.
https://docs.netapp.com/ontap-9/topic/com.netapp.doc.exp-vol-move/GUID-10F57AAF-77B4-43BF-B8D3-B35AC36315AF.html
