ONTAP Discussions
Volume size not correct with contents - reclaim
dirkslechten
hello,
I have a thin provisioned volume of 5TB. There is only a CIFS share on this volume.
When I select all the files in my browser it says it has 2.5TB of files
But the system says it has 3.6TB in use
Filesystem               total       used      avail capacity  Mounted on
/vol/CIFS_BACKUP2/      5120GB     3643GB     1476GB      71%  /vol/CIFS_BACKUP2/
These are the options of the volume
vol options CIFS_BACKUP2
nosnap=on, nosnapdir=on, minra=off, no_atime_update=off, nvfail=off,
ignore_inconsistent=off, snapmirrored=off, create_ucode=on,
convert_ucode=on, maxdirsize=45875, schedsnapname=ordinal,
fs_size_fixed=off, guarantee=none, svo_enable=off, svo_checksum=off,
svo_allow_rman=off, svo_reject_errors=off, no_i2p=off,
fractional_reserve=0, extent=off, try_first=volume_grow,
read_realloc=off, snapshot_clone_dependency=off, dlog_hole_reserve=off,
nbu_archival_snap=off
There are no snapshots on the volume
snap list CIFS_BACKUP2
Volume CIFS_BACKUP2
working...
No snapshots exist.
I know that the Volume is thin provisioned, but how can you reclaim space from this?
Thank you in advance
3 REPLIES 3
aborzenkov
Do you have large number of small files (less than 4K)?
dirkslechten
there are 125 files and 5 folders.
It is a B2D folder where large images are saved such as acronis etc
SNAPCLONE
I had a very similar problem.  A few questions:  What version of ONTAP are you running?  And, is Storage Efficiency enabled on this volume?
I'm on 8.1, and was able to reclaim the missing space by running the following two commands:
sis start -s <volume_name>
When it completes (mine took over 12 hours):
sis off <volume_name>
The bug is outlined here: http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=657692
