ONTAP Discussions
When Exporting to CSV I'm receiving System.String[] in spreadsheet
whf_netapp
Hello,
When I run the following PowerShell command:  Get-NcExportRule -vserver *
all the columns on the screen populate with the proper information, however when I export it to a .csv file, the columns Protocol, RoRule, RwFule and SuperUser are all populated with System.String[].
Anyone have any suggestions?
1 ACCEPTED SOLUTION
HUX20002000
That's happening because those columns are arrays rather than strings (hence the curly brackets in the onscreen output) and Export-Csv doesn't know what to do with those. There are various ways to deal with that. I usually use PowerShell custom objects with the 'join' operation for columns that have arrays. For example:
$output = @()
$rules = Get-NcExportRule
foreach($rule in $rules)
   $output += [pscustomobject]@{
      'PolicyName' = $rule.PolicyName
      'RuleIndex' = $rule.RuleIndex
      'ClientMatch' = $rule.ClientMatch
      'Protocol' = $rule.Protocol -join(', ')
      # etc.
$output | Export-Csv -Path [\path\to\.csv] -NoTypeInformation
So if 'Protocol' for a particular rule shows as '{nfs3, cifs, flexcache}' onscreen (for example), it will display as 'nfs3, cifs, flexcache' in the .csv file.
2 REPLIES 2
HUX20002000
$output = @()
      # etc.
whf_netapp
Thank you very much. This worked perfectly and I learned something.
