ONTAP Discussions
can not restore ossv backup using Netapp management console (dfm)
vineetanandjha
Hello,
I am not able to restore a backup using Netapp management console (dfm) where the backup was done using protection manager. The primary system is a Microsoft cluster and the secondary system is a fas2040 filer. while restoring i am getting the Below errors
bppmdch04-vip: Connection had exception bppmdch04-vip: Failed to connect to filer
for now i had a work around
Create a CIFS share to /vol/vol_name/qtree_name
\\filer\share_name$\~snapshot\name_of_snapshot
Drag and drop the file or folder
But it should be restored by using Netapp management console (dfm) which is not working and restore job is failed.
1 REPLY 1
ASHWINPAWARTESL
Hi Vineet,
Can you attach ossvinfo dir.
To collect, go to:
C:\Program Files\netapp\snapvault\bin>OSSVINFO.exe -s filer -l root:password ossvinfo
'Ossvinfo' is saved in /bin directory in the same path.
Thanks,
-Ashwin
