ONTAP Discussions
mariadb service does not start with trident volume while dockerhost have public IP
qSkills
im not sure to start this discussion on the right place. I havent found trident
mariadb container does not start mariabdb service while dockerhost have a public ip, everything else looks good. The volume is visible the volume is mapped into the container to /var/lib/mysql. Data is accessible. Rights are correct. Volume is read write.
the container is running only the mariadb service doenst come up. Changing the dokerhost IP back to internal ip
the mariadb service starts without any issues.
we are not using kubernetes only docker, docker-compose with trident plugin
  • Trident version: latest from this month
  • Container runtime: 20.10.24+dfsg1, build 297e128
  • docker-compose version: version 1.29.2, build unknown
  • OS: Debian12
  • NetApp backend types: Netapp AFF A400
To Reproduce
changing dockerhost to public ip
trident config
"version": 1,
"storageDriverName": "ontap-nas-economy",
"storagePrefix": "trident_eco_prod_labs_",
"managementLIF": "172.16.21.100",
"dataLIF": "172.16.21.31",
"svm": "corp_trident",
"username": "USER",
"password": "PASSWORD",
"aggregate": "n01_aggr1",
"limitVolumeSize": "300g",
"log-level": "debug",
"debug": true
docker-compose.yml
services:
guacd:
image: guacamole/guacd
networks:
- local
guac-serve:
image: guacamole/guacamole
links:
- guacd:guacd
- mariadb:mysql
ports:
- 8080:8080
environment:
- MYSQL_LOG_CONSOLE=true
- MYSQL_HOSTNAME=mariadb
- MYSQL_DATABASE=guacamole
- MYSQL_USER=guacamole
- MYSQL_PASSWORD=PASSWORD
- GUACD_HOSTNAME=guacd
- GUACD_PORT=4822
networks:
- local
mariadb:
image: mariadb:11.5
environment:
- TZ=Europe/Berlin
- MYSQL_ROOT_PASSWORD=PASSWORD
- MYSQL_PASSWORD=PASWORD
volumes:
- debian12_guacamole:/var/lib/mysql
networks:
- local
volumes:
debian12_guacamole:
driver: trident_eco:latest # Ensure this matches your plugin name
# driver_opts:
# size: "30G"
networks:
local:
driver: bridge
1 ACCEPTED SOLUTION
PravinKumar
Hi
  • Trident task is to provision volume, as I see from your update it is working as expected.
  • Container mariadb service goes down while changing docker host to Public IP, needs to be investigated from Kubernetes side.
  • If any further assistance on this on Trident perspective, request you to open support case with us.
Thanks and Regards,
Pravin Kumar
1 REPLY 1
PravinKumar
Hi
Thanks and Regards,
Pravin Kumar
