ONTAP Discussions
no snapshot used info in volume-info
HAIT_NETAPP
I am trying to get volume used infomation, equivalent to "df" command.
I use volume-info, however, there is no snapshot used infomation:
        <volume-info>
            <name>testvolume</name>
            <uuid>48831895-1a4asfdsd3-95f7-123safsadf2</uuid>
            <type>flex</type>
            <block-type>64_bit</block-type>
            <state>online</state>
            <size-total>1099511627776</size-total>               # in byte
            <size-used>153443323904</size-used>                             # in byte
            <size-available>946068303872</size-available>               # in byte
            <percentage-used>14</percentage-used>
            <snapshot-percent-reserved>75</snapshot-percent-reserved>      # in percent
            <snapshot-blocks-reserved>3221225472</snapshot-blocks-reserved>  # in block namely kbyte
            <reserve-required>0</reserve-required>
            <reserve>0</reserve>
            <reserve-used>0</reserve-used>
            <reserve-used-actual>0</reserve-used-actual>
            <files-total>31876689</files-total>
Can someone tell me how and where I can get snapshot used information?
0 REPLIES 0
