ONTAP Discussions
problems installing from dvadmin
MIKEMWALK
Hi, I have been having problems while trying to install ONTAP Edge from dvadmin
I have installed the Data ONTAP-v Installer (from 821RC2_121_v_installer.ova) and get an error when running the setup wizard
Error encountered while creating VM
[13] InvalidArg: vm invalid - Virtual machine argument is invalid or missing
[81] VmCreateOvfErr: Cannot create VM 'node1'
Any ideas what could be causing this?
It seems to have picked up the VM Name ('node1') enough to fill in the second line of the error
1 ACCEPTED SOLUTION
MIKEMWALK
Sorted it out
The problem was caused by VM license restrictions preventing dvadmin from running properly
the hostd.log was reporting multiple instances of:
--> (vim.fault.RestrictedVersion) {
-->    dynamicType = <unset>,
-->    faultCause = (vmodl.MethodFault) null,
-->    msg = "",
This was because I had installed a free ESXi license on the test server by mistake
5 REPLIES 5
venkat3
Hi Mike,
Would it be possible for you to post a screenshot and describe some more steps on how you hit this problem
-Srinivas
venkat3
Thanks Mike for the screenshots.
I do see the error message clearly in pics
few more things.
a) Which VC / ESX version is being used here to deploy Data ONTAP-v Installer .ova
b) Does VC/ESX throw some warning / error messages in the VI client page.
-Srinivas
MIKEMWALK
The installer is deployed on ESXi, 5.1.0, 1065491 (5.1 update 1) and I am attempting to create a VM on the same host
I get no warnings in the vSphere window, it gives me a few recent tasks logged while configuring the options:
"Find entity by IP" *2
"Refresh storage information" *
Nothing comes up after it starts creating the VM
Is the vm argument mentioned in the error one of the user supplied arguments or is this one hidden in the OVF package that is being deployed?
MIKEMWALK
Sorted it out
-->    msg = "",
