ONTAP Discussions
resizing volume via powershell module command started to fail after ontap upgrades
plexOntap
Hi, after an ontap upgrade we are now getting a cryptic message to me and I can no longer use the code to resize volumes. The help file for this command is not super detailing and it doesn't matter if I try to grow 1mb or one tb  and it happens on any volume for any svm across 3 filers.
here is the command that now fails and the error it throws
Set-NcVolSize -Name $vol2.Name -Size +1tb -VserverContext:$vol2.Vserver
Set-NcVolSize : One or more of the fields "-max-autosize","-size" are being set/modified. Set the values such that "-max-autosize" and "-size" should always be less than or equal to 600.
At line:1 char:1
+ Set-NcVolSize -Name $vol2.Name -Size +1tb -VserverContext:$vol2.Vserv ...
+ CategoryInfo : InvalidOperation: ({nccluster]:NcController) [Set-NcVolSize], EAPIERROR
+ FullyQualifiedErrorId : ApiException,DataONTAP.C.PowerShell.SDK.Cmdlets.Volume.SetNcVolSize
the 600 stays constant across any volume  or any filer
any one know how to debug this further or know the answer to why this used to work and stopped after the code upgrades?
Name Version
Set-NcVolSize 9.15.1.2410
Name Address Vserver Version
netapp01-clust... 172.xx.xx.152 NetApp Release 9.14.1P8: Fri Sep 13 07:12:27 UTC 2024
thanks
1 REPLY 1
cpatterson
Hi plexONTAP - did you ever receive a reply or develop a workaround for this?
