ONTAP Discussions
system state backup issue
MANISH_KUMA
Hi all,
I am facing the issue with System state backup. i am unable to start the system state backup in win2k8 and win2k3.
Please suggest.
2 REPLIES 2
amirm
Manish Kumar,
Could you please post the exact error message you are facing and the steps you are following?
Thanks,
-Amir
MANISH_KUMA
when i run the command to start the backup :- sudo ssh gbrhou01xd001 snapvault start -S source client:systemstate detination filer.
once i run the command it shows transffer started but after 5 min once i check the status it shows secondary snapvault is on. and backup not started.
