ONTAP Discussions
using conditional execution in CLI
mgilbert
Is there a way to use conditional logic on the OnTap CLI between different fields? Like if I wanted to get all users that are over 1TB OR using more than 1million files? E.g. something like
quota report (-disk-used >1TB | -files-used >1000000)
3 REPLIES 3
Girton
I don't have access to a cluster that has quotas enabled, so I wasn't able to get any real results, but I was able to successfully execute a CLI command similar to what you provided:
quota report -disk-used >1tb -files-used > 1000000
Have you tried running a similar command?
GidonMarcus
Hi @Girton ,
i think he wishes to make an OR statement rather an AND - that your example will result.
i tried to find a way as well. but the only thing worked for me is just to execute the command twice...
quota report -disk-used >100g;quota report -files-used >500
Gidi
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
mgilbert
Thank you for the reply. You are correct; that's what I was going for. I guess I'll just have to settle for looking for similarities between two separate commands.
