ONTAP Discussions
why does my FC/FC0E license keep going into disable mode
VKALVEMULA
Hi
every time i logout of System Manager, the FC/FCoE license go into disable mode.
and i cannot see "LUN" options under Storage tab.
i need to enable FC/FCoE again to see the "LUN" under Storage tab.
thanks in advance
vj
1 ACCEPTED SOLUTION
stjerna
Please check your System Manager and Data ONTAP versions. This sounds like a bug that was fixed in the latest release of System Manager, 2.0.1. Older versions did not understand Data ONTAP 8.1 enable/disable for previously licensed features.
Hope this helps,
Erik
2 REPLIES 2
stjerna
Hope this helps,
Erik
VKALVEMULA
thanks erik
