ONTAP Hardware
3020 CFE boot fail
CLUSTERMAGNET
Guys
  Used 3020 Filer, failing to boot, not getting anywhere from CFE...
  Not able to boot_backup or boot_ontap or boot_primary...  the error says Could not load fat://ide0.0/backup/X86_ELF/kernel/primary.kern.
  Screen shot: (pardon, had to take the screenshot from rdp)
  http://img90.imageshack.us/img90/2298/screenshot20110510at652.png
Thanks!
2 REPLIES 2
aborzenkov
You need to netboot filer and download boot image on Compact Flash card.
CLUSTERMAGNET
Thanks!
I've ifconfig'ed a nic, got dhcp, typed netboot http://10.0.blah/733_netboot.q  (which exists)... and got
Socket not connected, *** command status = -39
I've tested the http server, file downloads fine... md5sum 7546313fe64a2619e9bebaa03f29e2e4
Thanks!!!!!!!!!!!!
