ONTAP Hardware
4 node cluster split
StorageRM
Hello,
We have 4 node cluster of
8060 - 2 node ssd drives.
8020 - 2 node hynbrid sas an NL-sas drives.
we want to split cluster one - 8060 and second 8020. Already migrated data.  Existing version is 9.1p18.
First we should upgrade and then split. Newer version has remove-nodes command.
What are the steps or procedure to split. After removing 8020 from existing cluster should i reconfigure 8020 nodes or how i will access 8020 cluster.
1 ACCEPTED SOLUTION
andris
Upgrading ONTAP is a good idea. 9.1 went EOVS a while ago,
For 9.1-9.3, you would use the cluster unjoin command.
https://docs.netapp.com/us-en/ontap-cli-93/cluster-unjoin.html
I assume you plan to leave the 8080 in the existing cluster and unjoin the 8020 from it.
Follow this document to ensure a successful removal:
https://docs.netapp.com/us-en/ontap/system-admin/remov-nodes-cluster-concept.html
Reinitialize the 8020 to set it up as a new 2-node cluster.
https://kb.netapp.com/onprem/ontap/os/How_to_decommission_or_repurpose_an_HA_Pair_with_ONTAP_9
1 REPLY 1
andris
