ONTAP Hardware
[7.3] upgrade_ownership not recognized
JACKONEILL
Hi,
Sorry if this is not the place to ask.
Has anybody an idea of what's wrong :
> priv set advanced
*> disk upgrade_ownership
disk: Did not recognize option "upgrade_ownership".
Extract of sysconfig -a :
NetApp Release 7.3: Thu Jul 24 14:34:16 PDT 2008
Model Name: FAS3020
Shelf 1: AT-FCX  Firmware rev. AT-FCX A: 35  AT-FCX B: 35
We have two other filers (clusterized) with /_exactly_/ the same version 7.3 (2008) and the same shelf. The only difference is that the one above is stand-alone. And both accept command "disk show", as they are in software based ownership; that is why I think that upgrading wouldn't change anything.
Ragards,
1 ACCEPTED SOLUTION
aborzenkov
Support for online changing to software based disk ownership is available starting with 7.3.1 In 7.3 you have to boot in maintenance mode.
3 REPLIES 3
scottgelb
Disk show gives output on this system?  Then software ownership is already enabled and you should be good to go.
aborzenkov
JACKONEILL
Thank you aborzenkov, I upgraded to 7.3.3, changed ownership, rebooted and now we do have "disk show".
