ONTAP Hardware
Performance status for NetApp flash cache
TOBIAS1979
Hi
We have this weekend installed 2x256Gb flash cache in our two FAS3240 controllers. What can I expect from this when do I start to se some effect of the installation? How can I see the perfroamce status of the flash cache?
Rgds
Tobias
3 REPLIES 3
gben
Hi,
TR-3832 - Flash Cache Best Practicse Guide:
stats show ext_cache_obj
This gives you only a point-in-time view of the data in the counters
TOBIAS1979
Hi
Thanks for the *.pdf, now I can chek the performance status. If someone has done this flasch cache installatione I would like to here from you
what it really did for their environment. What happens to the VMWare environment, it is possible to access the CIFS share faster?
/T
CCOLEMAN_
Hey Tobias,
I have done several Flash Cache installations, and also have 1 512GB card on each controller in my lab environment with only SATA disks. (NFS, CIFs, and ISCSI)
In my lab I saw a boost in all protocols (and some NetApp features), and I also combined flexcache with my VMware NFS volumes. (the instructions to do this are in TR-3832)
But to answer your question, I just see a big boost in response times, and even a little write performance across the board.
These cards easily compensate for my slow SATA drives.
Here are some benchmarks for you,
Baseline submission: FAS3140 with 224 Fibre Channel drives
http://www.spec.org/sfs2008/results/res2010q2/sfs2008-20100415-00156.html
Second submission: FAS3140 with 56 Fibre Channel drives plus Flash Cache
http://www.spec.org/sfs2008/results/res2010q2/sfs2008-20100415-00157.html
Third submission: FAS3140 with 96 SATA drives plus Flash Cache
http://www.spec.org/sfs2008/results/res2010q2/sfs2008-20100415-00158.htm
