ONTAP Hardware
A250/FAS500f FC initiator Mode X1154
ADVUNIBN1
Hi all,
is there no way to have FC initiator ports on a A250/FAS500f?
There is a PCI Card X1154. The Note Description "Target mode adapter only. Foreign LUN import (FLI) requires initiator mode."
Will the CLI command "system hardware unified-connect modify -t initiator adapter_port" really not work?
I hope anyone can help me...
Thanks!
Regards
Benny
1 ACCEPTED SOLUTION
andris
Unfortunately, the driver/firmware for the X1154 FC ports do not support initiator mode, and there is no plan to do so. Hence the footnote in Hardware Universe.
2 REPLIES 2
Ontapforrum
I checked HWU site for this X1154, it only has Target-only Mode. One workaround would be to have a Non-AFF(Having Initiator Mode Port) joined to A250 as one Cluster, then first bring the LUN into the Non-AFF and from there to A250. Try to look up information around this or you might want to speak with NetApp to see if there is any other ways.
https://docs.netapp.com/us-en/ontap-fli/san-migration/concept_using_fli_to_import_luns_into_all_flash.html
andris
