ONTAP Hardware
A300 aggregate with mix drive
adnan_scl
Dear Friends,
May I use mixed disk drives in one same aggregate (half SAS 960GB + half Flash 3.2TB) in A300 storage?
Thanks in advance & looking forward to hear from you soon.
1 ACCEPTED SOLUTION
andris
No, you cannot create Flash Pools/hybrid aggregates on an AFF A300.
AFF systems only support SSDs. HDD's are unsupported.
2 REPLIES 2
Sahana
Hi,
You can create a hybrid aggregate.
Please refer https://kb.netapp.com/app/answers/answer_view/a_id/1002408/loc/en_US
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
andris
