ONTAP Hardware
Thin LUN autogrow size limitations
Muthuraj
Hi All
We are managing NetApp FAS 2040 in our environment.
I would like know, is a thin LUN on thin volume will autogrow. If it so , the LUN size will be increased upto the volume size or is there any particular percentage of space will be increased.
Please do the needful.
Thanks in advance.
1 REPLY 1
Sahana
Hi,
The autogrow limitations depends on teh settings. Please refer https://library.netapp.com/ecmdocs/ECMP1196817/html/volume/autosize.html
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
