ONTAP Hardware
AF200 Controller replacement without support
jtejada
Hi all,
A customer has an AF200 system wich is near of end of support and we are evaluating if we can maintain this system by ourselves. The most complicated situation I see is if one of the controllers fails and we have to replace it. As I know without support we can't generate replacement licenses if we buy a refurbished controller but what about if that controller comes with its licenses, ¿It could work?
Thanks in advance
2 REPLIES 2
AlexDawson
ONTAP licenses are not legally transferable, even if you have the codes. But it should work, if you have the codes.
chenguanghui
hello:
  This is works   if the controller comes with a matching license
