ONTAP Hardware
Network ports down
lucifer6
I am rebuilding FAS 2660. after recabling the ports are not coming up. DC ops confirmed the connections are in place and network team has enabled ports from their side. need some one help on this .
Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status
e0c       Default      -                down 1500  auto/auto  -
e0d       Default      -                down 1500  auto/auto  -
e0e       Default      -                down 1500  auto/auto  -
e0f       Default      -                down 1500  auto/auto  -
7 REPLIES 7
SpindleNinja
Have you tried just admin down and admin up them?
lucifer6
i did admin up and down. still the port is down. I am asking the dc team to check the cabling again .
SpindleNinja
Cabling and switch config.   That's about it i think that's left to check.
AlainTansi
Hi lucifer6
There could be couple of issues leading to port down, we can always begin narrowing this down by;
  1. Reseat the cables and the SFP that goes in port <portname> on controller side, replace cable/SFP
  2. Check connection with the switches.
  3. Reseat cable on switch port, replace cable/SFP
  4. Try other switch ports to confirm connectivity
paul_stejskal
Did they plug into the right node? Have them check serial # on the system's chassis and confirm it is the right one.
amans
Hi,
So those are UTA ports, have you configured them properly ?
" ucadmin show " command will give you the port configuration.
Regards,
Aman
liu
You can check controller ports, reinsert ports, replace cables,
check switch ports and cables,
or try controller ports to test with other switch ports
