ONTAP Hardware
Advice for Downgrading FAS8200 from ONTAP9.6 to ONTAP9.3P5 via Boot Menu #7 'Install new sw first'
nzmarkc
We have 2 _new_ FAS8200's that need to be downgraded from ONTAP9.6 (which I believe comes as the OS) to ONTAP9.3P6 so:
  • the first FAS8200 can be added to a switched cluster and
  • the second can do a headswap ARL
I would like to speed up the process by dropping ONTAP9.3P6 onto the FAS8200 via the boot option 7 'install new software first' before any connections (shelves, network, etc.) are made so it boots to 9.3P6 after connecting it up. I know NetApp says "This menu option is only for installing a newer version of ONTAP software on a node that has no root volume installed. Do not use this menu option to upgrade ONTAP" but these have not been turned on yet and I was hoping to save a decent amount of time this way.
Or should I use the Updating an ONTAP cluster disruptively (https://docs.netapp.com/ontap-9/index.jsp?topic=%2Fcom.netapp.doc.dot-cm-ug-rdg%2FGUID-08597754-747A-4224-9167-7170F7E3E300.html)?
Does anyone have any experience and/or advice they can relate to me? E.g.
  1. Which one is better
  2. troubles/gotchas for either
  3. Smooth sailing indicator for which one
  4. etc.
Thank you in advance.
2 REPLIES 2
SpindleNinja
Since there's nothing on there, I would just do opt 7.    For the nodes you plan you join to the existing cluster, I would also re-init after you downgrade.
Also to note,  I recall having to do a multi-step downgrade before.  So you might have to step 9.6 -> 9.5 ->9.4? -> 9.3.
I would also recomend patching to the latest 9.3P release to avoid this bug:
  https://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=1250500
aborzenkov
Older version may not be able to access disks used by newer version. So before directly installing 9.3, remove all aggregates, unpartition disks, if possible, zero spares (not sure if it works from maintenance mode) and unassign disks.
Once I observed old version crashed when booted on new firmware. I had to downgrade firmware as well.
So doing official revert is more fool proof, but requires working cluster and takes more time.
