ONTAP Hardware
After clean configuration FC problem
ilgiz_gantek
Hello all,
I have problem after clean system configuration.
I have FAS2040 systems.
License:
fcp ENBALE
demo02: fcp
fcp: FCP is not licensed.
demo02> fcadmin config
                  Local
Adapter Type      State                  Status
  0a   target     CONFIGURED             offline
  0b   target     CONFIGURED             offline
demo02> license delete fcp
license delete: "fcp" is an included feature and cannot be deleted.
demo02>
How I can enable FCP?
1 ACCEPTED SOLUTION
ilgiz_gantek
Dear All,
Problem solved.
If you have same problem. Please connect to FAS via NetApp OnCommand System and ENABLE FCP license.
From CLI you can't enable FCP license.
I don't know it is bag or feature :-).
Thanks
2 REPLIES 2
ilgiz_gantek
Dear All,
Problem solved.
Thanks
santosf
ilgiz_gantek
Yes you can enable FCP license from the CLI.
using: options licensed_feature.fcp.enable on
Some features on some platform models require that you use the options licensed_feature.featurename. enable commands to enable them instead of entering a license key.
