ONTAP Hardware
All Lun's serial numbers in Hex format
ckirim
Helloo,
With the 7 mode command;
filer> lun serial -x <lun-path>
I can see the serial number one of the given lun. But I wanna just list all the serial number at the same time in one command set?
Have somebody any idea? ( with * I can not !!)
4 REPLIES 4
ckirim
Hello ,
Thank you for your reply. I have already visited this link but this instruction is showing just all serial numbers in normal format not in HEX and at the end of the lun Path. I want to actually only all the serial numbers in a same outputs in HEX.
Best Regards
asulliva
Hello @ckirim,
From the cluster shell, use this command:
lun show -fields serial-hex
Hope that helps.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
ckirim
Hello Andrew,
I think this solution is for c-mode. I can not see any "-fields" parameters in 7 mode
