ONTAP Hardware
Monitoring FAS2050 by SCOM 2012 R2
AlbertT
Hi,All:
       i'm using the SCOM2012 R2 to monitor my storage-NetApp FAS2050, Following the USER GUIDE,i installed the SCOM-Management-Pack-WSX64-03.00.0002.3000 to RMS and one Agent-Managed server.As the USER GUIDE said ,the next step is to add the array by using the 'NetApp Storage Array Discovery' ,but i failed in this step,i running the discover program and add the controller 1&2 address,it comes an error(No storage array Found).PIng the ip address is ok。the ip of FAS2050 is 172.16.11.11&172.16.11.12 ,and the ip of RMS and Agent-Managed server is 172.24.62.82/172.24.62.90。i run the discover program on the Agent-Managed server.Did i do something wrong?Need some help.
Best regards
1 REPLY 1
hariprak
Hi,
Hope this best practice guide helps,
http://www.netapp.com/us/media/tr-4354.pdf
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
