ONTAP Hardware
Are 1 TB drive size supported in DS14Mk2-AT attached to a FAS3050C running ONTAP 7.3.6?
ggg
A general support question: I am expanding a FAS3050C controller by adding another DS14Mk2-AT shelf, are 1 TB drive sizes supported if the controller is running ONTAP v7.3.6? I looked at the compatibility matrix and it shows the last drive as 500GB but it was not clear if any larger drives are supported.
Thanks,
G.
1 ACCEPTED SOLUTION
georgevj
Looks like it is supported. Please see the results from hardware universe. (http://hwu.netapp.com)
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
2 REPLIES 2
georgevj
ggg
Thanks much George! I was not skilled at pulling the data from hwu...:)
Greg
