ONTAP Hardware
supported SFP for (Dual-port, QLogic CNA 8112(8152) rev. 2)
sherifafifi
hi all,
i installed Dual 10G Ethernet Controller CNA SFP+ (Dual-port, QLogic CNA 8112(8152) rev. 2) on FAS3140 8.0.2P6 7-Mode.
the status of the card always unknown/down even after starting up the slots
sysconfig output :
        slot 3: Dual 10G Ethernet Controller CNA SFP+
                e3a MAC Address:    00:c0:dd:26:1f:50 (auto-unknown-down)
                e3b MAC Address:    00:c0:dd:26:1f:52 (auto-unknown-down)
>ifconfig e3b
e3b: flags=0x748867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.1.10 netmask 0xff000000 broadcast 10.255.255.255
        ether 00:c0:dd:26:1f:52 (auto-unknown-down) flowcontrol full
>ifconfig e3a
e3a: flags=0x748867<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 192.168.1.12 netmask 0xff000000 broadcast 10.255.255.255
        ether 00:c0:dd:26:1f:50 (auto-unknown-down) flowcontrol full
and in the messages log : ispcna.mpi.sfp.notSupport:CRITICAL]: The SFP in adapter 3b is not supported.
so please can you adivce whatst he supported SFP to be used , your quick reaponae is apprciated
4 REPLIES 4
aborzenkov
Please paste output of
priv set advanced
sysconfig -ca
sysconfig -v
sherifafifi
na>sysconfig -ca
sysconfig: slot 2 OK: X2054A: QLogic ISP 2432; PCI-E quad-port Fibre Channel (QLE2464)
sysconfig: slot 1 OK: X2065A: PMC PM8001; PCI-E quad-port SAS (PM8003)
sysconfig: slot 3 OK: X1140A: QLogic ISP 8112; Dual Ported 8152 FCoE CNA Adapter (PCIe) Copper
sysconfig: slot 4 OK: X1049A: PCI-E Quad 10/100/1000 Ethernet G20
na>sysconfig -v  3
                Device Type:        ISP8112
        slot 3: Fibre Channel Target Host Adapter 3a
                (Dual-channel, QLogic CNA 8112 (8152) rev. 2, <OFFLINED BY USER/SYSTEM>)
                Firmware rev:     5.3.4
                Host Port Addr:   000000
                Cacheline size:   16
                SRAM parity:      Yes
                FC Nodename:      50:0a:09:80:89:4b:4a:84 (500a0980894b4a84)
                FC Portname:      50:0a:09:81:99:4b:4a:84 (500a0981994b4a84)
                Connection:       No link
                SFP Vendor Name:  HP-A     BROCADE
                SFP Vendor P/N:   AJ716B
                SFP Vendor Rev:   A
                SFP Serial No.:   UAA413317066251
                SFP Connector:    LC
                SFP Capabilities: 2, 4, 8 Gbit/Sec
        slot 3: Fibre Channel Target Host Adapter 3b
                Firmware rev:     5.3.4
                Cacheline size:   16
                SRAM parity:      Yes
                FC Portname:      50:0a:09:82:99:4b:4a:84 (500a0982994b4a84)
                Connection:       No link
                SFP Vendor Rev:   A
                SFP Serial No.:   UAA413317030451
                SFP Connector:    LC
aborzenkov
X1140A is supported with Twinax (copper) cables only, no SFP. You would need X1139A, which comes with SFP included.
saranraj456
We had a same issue after adapter replacement , but the weird thing is one port in the same adapter is still functioning.
my Suspicion is on Cable , however netapp recommended to do the replacement of SFP , any thoughts on that?
        slot 1: Dual 10G Ethernet Controller CNA SFP+
                e1a MAC Address:    00:c0:dd:1b:78:dc (auto-10g_sr-fd-up)
                e1b MAC Address:    00:c0:dd:1b:78:de (auto-10g_sr-fd-down)
        slot 1: Fibre Channel Target Host Adapter 1a -Functioning still
                Firmware rev:     5.3.4
                Cacheline size:   8
                SRAM parity:      Yes
                FC Nodename:      50:0a:09:80:8d:41:d3:66 (500a09808d41d366)
                FC Portname:      50:0a:09:81:9d:41:d3:66 (500a09819d41d366)
                Connection:       No link
                SFP Vendor Name:  OPNEXT,INC
                SFP Vendor P/N:   TRS2000EN-SC01
                SFP Vendor Rev:   0000
                SFP Serial No.:   T10H64761
                SFP Connector:    LC
                SFP Capabilities: 10 Gbit/Sec
        slot 1: Fibre Channel Target Host Adapter 1b
                Firmware rev:     5.3.4
                Cacheline size:   8
                SRAM parity:      Yes
                FC Portname:      50:0a:09:82:9d:41:d3:66 (500a09829d41d366)
                Connection:       No link
                SFP Serial No.:   T10H64803
                SFP Connector:    LC
