ONTAP Hardware
BES-53248 cluster switches
Loxley
Hello community, This is my first post. I'm setting up our first netapp starting with the BES-53248 switches. I have 2 of them. Our environment requires that we use vLans for security. I have everything setup on each individual switch but I don't know how to cluster them together. I have a 100gb connection on interface 0/55 and 0/56
0/55 Enable Auto 100G Full Up Enable Enable long
0/56 Enable Auto 100G Full Up Enable Enable long
The port channel shows as down.
(spfcs01)(Config)#show port-channel 1
Local Interface................................ 1/1
Channel Name................................... ch1
Link State..................................... Down
Admin Mode..................................... Enabled
Type........................................... Static
Port-channel Min-links......................... 1
Load Balance Option............................ 3
(Src/Dest MAC, VLAN, EType, incoming port)
Mbr Device/ Port Port
Ports Timeout Speed Active
(spfcs01)(Config)#
I'm not a big network guy so I'm struggling to figure this part out.
Thanks
1 ACCEPTED SOLUTION
andris
I'm glad to hear you found out about the reference configuration files (RCF).
Here's some useful links to check out...
Documentation:
https://docs.netapp.com/us-en/ontap-systems-switches/switch-bes-53248/overview-bes53248.html
Compatibility Matrix (to help you decide which EFOS version and RCF version to use):
https://mysupport.netapp.com/site/info/broadcom-cluster-switch
The support contract for the BES-53248 you have is with Broadcom. Here's info on this and how to register support for the switches.
https://mysupport.netapp.com/site/info/policies-and-offerings/broadcom
2 REPLIES 2
Loxley
Looks like I missed a step and didn't install the RCF file. Another step closer
andris
Documentation:
