ONTAP Hardware
BSAS?
ramjet666
Hi,
I have tried to find out why there is BSAS & SAS disk types when creating an aggregate to no avail. What is BSAS?
Regards,
Roger.
7 REPLIES 7
mkopenski
Serial Attached SCSI (SAS)
Bridged SAS (BSAS) - SATA drives
RichardSopp
Hi Roger,
BSAS stands for Bridged SAS.
When you see that on a NetApp system it means you have SATA disks in a SAS enclosure.
Based on current product offerings this would be a DS4243 disk shelf.
Are you seeing both BSAS and SAS disk types in the same aggregate?
I didn’t think that was possible.
Richard
BALAJI_VENKATRAMAN
Also refer to the below document
https://library.netapp.com/ecmdocs/ECMM1277794/html/smg/GUID-2F317E55-FBC5-46A1-B121-215861E1258A.html
This show the mix and match of certain types of disks in the same aggregate
Mr_Bailey
Im not that familiar with netapp. I only know the basics. Anyway I was reading on this forum below:
http://community.netapp.com/t5/FAS-and-V-Series-Storage-Systems-Discussions/BSAS/td-p/49090
and you asked "Are you seeing both BSAS and SAS disk types in the same aggregate?"
I do see this and i was trying to figure out which Netapp has what. I was told one has Sata (BSAS) and another has SAS. I see both types in both Netapps. Why is this? Also would you know or know of any documentation on how to learn your current Netapp configuration. What i mean by that is how they are connected to the network and to eachother? these netapps are stored in a Data Center hundreds of miles away. I understand these might be stupid questions but i figure i can learn more about SAN storage. I ve attached screenshots of each netapp.
chad_petrie
Is it posted anywhere what the drive specs are on BSAS? I am interested to know what kind of IO it can support.
mkopenski
I don't know of anything posted. BSAS are basically the Sam as 7200 sata drives,
BALAJI_VENKATRAMAN
Richard is correct..that BSAS are the same as SATA and can be used as Tier 2 low performing applications or backup filers.
Check tr-3437 for more details
