ONTAP Hardware
performance measruement question
amiryo
Hi,
How can we measure different storage controller performance?
Are you familiar with storage performance measurements standards or benchmarks refer to different features(compression, de-dupe, encryption, …)?
Thanks,
Amir
1 REPLY 1
hariprak
Hi,
Perfstat (Performance and Statistics Collector) is a diagnostics data collection tool.
Key features of Perfstat:
1.Captures relevant performance information with one command.
2.Captures performance information simultaneously, for cross correlation.
3.Supported for all Netapp platforms, and selected client/host platforms.
4.Perfstat output is supported by end tools for parsing and analysis.
For Perfstat Vs Data ONTAP support matrix details refer, http://mysupport.netapp.com/NOW/download/tools/perfstat/
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
