ONTAP Hardware
Borrowing C-Mode filers
Ramanan
Hi,
 I am Ramanan from Micro Focus, Bangalore. We have to qualify our Enterprise backup tool (Data Protector) with Ontap C-Mode 9.11 on Linux and Windows platforms. Is it possible to borrow C-Mode 9.11 for some time? If it is possible, please let me the procedure and cost.
Thanks
Ramanan M
1 ACCEPTED SOLUTION
AlexDawson
Regretfully we cannot provide recommendations of that type and would ask you to use Google to find them.
Thanks!
5 REPLIES 5
AlexDawson
Hi there! We have a simulator available - would that be suitable?
To obtain access to that, register as a partner with us at https://netapp.tap.thinksmart.com/prod/Portal/ShowWorkFlow/AnonymousEmbed/26c8b2c2-68d6-4b30-b522-a81075a97c56 - from there, you will get access to our simulator.
Regarding first party loans of hardware for partners, we have suspended some of those programs regionally based on semiconductor shortages. When you sign up you will receive contacts to discuss further if that is appropriate.
Alternatively, you may be able to find third party netapp controller rentals in your local area using Google or a similar tool.
I hope this helps. Thanks for your interest in partnering with NetApp.
Ramanan
Hi Alex,
 Thanks for your reply. But we need physical filer with Servers connectivity for our testing @Bangalore. Could you please send the list of rental vendors?
AlexDawson
Thanks!
Drew_C
You could try to connect with a partner in your region: https://www.netapp.com/partners/partner-connect/
Community Manager \\ NetApp
Ramanan
Hi Drew
 Thanks, let me try
