ONTAP Hardware
Broadcom 8 Port (SW-BES-53248A1-G1-8P-LIC) Cluster switch Configuration guide
GaneshDeshmukh
Hi All,
Hello All,
Need a bit of help, we are planning to convert switch-less cluster (Ontap 9.5P10) to switched cluster, so customer  buy couple of Broadcom 8 Port interconnect switch (BES-53248A1-G1), could anyone please share the commands to setup inter-cluster switch, which will help us to install the switch and configure to NetApp standards.
--Regards
1 ACCEPTED SOLUTION
andris
That part number (SW-BES-53248A1-G1-8P-LIC) is an 8-port activation license for the Broadcom-supported BES-53248 cluster switch. Instructions for adding these licenses are in this KB:
https://kb.netapp.com/Advice_and_Troubleshooting/Data_Protection_and_Security/MetroCluster/How_to_add_Additional_Port_Licensing_for_the_Broadcom-Suppo...
For documentation on how to setup the BES-53248 switch and how to migrate from two-node switchless to switched, see:
Setup: https://docs.netapp.com/platstor/topic/com.netapp.doc.hw-sw-ix8-setup/home.html
Migrating to switched: https://docs.netapp.com/platstor/topic/com.netapp.doc.hw-sw-ix8-migrate-2n/home.html
2 REPLIES 2
andris
GaneshDeshmukh
Hi
