ONTAP Hardware
Cabling FAS2552 + 2 x DS2246 + 1 x DS4246
DCP-AU
Hello,
We have a FAS2552 (dual controller) with 2 DS2246 connected.  We want to add a DS4246 to this configuration.
From the documentation, I can see how to connect DS4246 to a dual controller FAS2252, but can't quite get my head around adding the DS4246 to a FAS2552 & 2 x DS2246...
Does anyone know how this should be cabled??
6 REPLIES 6
hariprak
Hi,
You can refer the link https://library.netapp.com/ecm/ecm_get_file/ECMP1197106
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
DCP-AU
Hello,
Thanks for responding; however that document is supplied with my system & doesn't reference the scenaio.
It references:
  1. FAS2552 connecting to multiple DS4246 shelves
  2. FAS2552 connecting to multiple DS2246 shelves
My scenario is a FAS2552 with 2 x DS2246 shelves (matching option-2 above), to which I need to add a DS4246 shelf.  This is where the problem begins.  The DS2246 are dual controller, so the cabling logic is clear, but the DS4246 is single controller & it is not obvious how to insert this into the loop (& essentially where).
Can you please provide more detail??
patrick404
The DS4246 definitely has 2 IOMs. There is one on top and one on bottom. It does look a little weird since the 2246 has the IOMS side-by-side. Treat the top one like you would the left one and the bottom like the right.
radek_kubka
DS4246 has definitely two IOM6 modules - in fact they are exactly the same, as those in DS2246 shelves (IOM6)
You can add the new DS4246 shelf non-disruptively at the end of the SAS stack.
Vishnup
Has the issue been resolved ?
davidrnexon
Hi DCP-AU, if you can provide a diagram how you have it cabled now I can help you cable in the new shelf by replying with the new cabling connections
